JFHenne
Oct 15, 2013Explorer
Jayco Kiwi water system
I am perplexed by my Kiwi 24B water system. The city water (pressurized) inlet is connected directly to the inlet side of the pump (Shurflo.) The outlet goes to a tee one side of which goes to a tube venting to the air beneath and the other through the floor and into the fresh water holding tank at the bottom center. Both sides of this tee have valves, the one to the vent is closed. How the heck can this work?
As it appears the pump pressurizes the water tank, but that cannot then provide water to the system as that tank is vented. Pressure would simply pump water out the vent to the ground.
Trouble is the system works fine! Can anyone tell me what I am not understanding here?
