myredracer
May 18, 2016Explorer II
One source of RV compartment doors is Challengerdoors.com They make custom sizes. There may be other manufacturers.
We have a 2 year old TT and the slam latches have been leaking and allowing water into the foam insulation and onto the floor inside our pass-through compartment on each side and there is some minor damage. :M I would assume you have keyed latches tho. I imagine fixing the floor would be a lot of work but it's possible but when you start it you could end up finding other things that need repair. If you did tackle the job, you'd have to change your username to LIKE2FIX... :D
