spadoctor
Mar 04, 2015Explorer II
My point exactly....I have never had to work on or adjust a ram type slide....cables ( especially the light weight ones used by BAL) stretch causing the slide to move uneven and needing adjustment....rams connected to a rack and pinion can not go out od sync without a component failure. As I stated I was not fond of things done in construction that I saw at the factory like shoddy install of the heat ducts (there were several folks there for repair on inop heat ducts....they us 1/2 inch NON T&G plywood for the floor...just name a few.
44,071 PostsLatest Activity: Aug 08, 2026
