Bama bluejay wrote:
The pump location on our White Hawk is located in the kitchen under the sink area. DH had to remove a panel to locate it. The on and off switch is located on the levels panel, which on ours is located on side of cabinet just inside the main entrance door.
X2 on both the pump location and switch location.
Edit: Guess that's the difference between a good dealer and a great dealer. OP said he wasn't told anything about the water pump, our dealer (Orlando RV), not only explained the pump and water system, the tech removed the panel under the kitchen sink, and showed us the pump location (along with the water heater bypass kit while he was under there). :)
