BadBeans
Nov 12, 2014Explorer
Jayco Winterization Question About Pumping Anti-Freeze
This is my first travel trailer and my first winter where I am doing my own winterization. I read up a lot on the forums and watched countless YouTube videos on the topic. I have already drained my tanks, drained my lines and blew them out via city water inlet with 30 psi. My next step is to add some RV anti-freeze. However, I have one question specifically about my Jayco Jay Flight. I am about to pump RV anti-freeze into my water system. My RV pump is already equipped with a hose for pumping out of the bottle. I noted it has a value I turn on to start the flow. It also has another value near it for the water intake hose from the fresh water tank, which is normally open.
Do I turn the valve for water hose coming from the fresh water tank closed, then pump anti-freeze into my water system? By closing this valve it likely prevents anti-freeze from backing into my fresh water tank, but I don't know for certain. However, how does that hose not freeze without anti-freeze or do I keep the value open when pumping in anti-freeze.
I hope that was clear. Anyways, thanks for the assistance.
