Overlandr
Mar 31, 2019Explorer
3HappyHicks wrote:
Hi all I'm new to this forum and the travel trailer thing. We just bought a Winnebago Micro Minnie with a weight of 3010 and I have a 2011 Jeep Grand Cherokee V6-Pentastar 290hp 3.6L engine. I bought a WDH/sway bar so I believe my tongue weight can be 350-400lbs based on the trailer weight, but with the WDH hitch does that increase my tongue weight allowance? I also bought the extra trailer brake controller for the inside of my jeep.
My jeep has a GVWR of 6500lbs, GAWR FRONT: 3200lbs and GAWR REAR 3700lbs. From what I have found my payload is 1240.
My question is basically this- we are traveling from CO to Moab in a couple weeks and I want to make sure my setup is good to go. I feel like it is adequate and if I take my time and go slow I should be able to manage this. Thoughts, recommendations, suggestions welcome.
Please and thank you in advance.
After reading your post and the many well intended posts, I registered so I can share my actual experience with you towing a Jayco X20E hybrid with a 2011 JGC Limited that had a factory tow package installed, brake controller 3.6L Pentastar engine, 5 speed auto transmission with 18" wheels. The Jayco X20E Hybrid was 3850 lbs dry, 350 lbs tongue.
We started off with a Husky WDH and 600lb round bars. The first couple of times on the road was literally white knuckle. We were getting pushed around every time someone passed, and if it was a transport truck, it was an effort not to get pushed out of my lane. Any little wind that hit us from the side felt like we shifted sideways as well.
So I took it into a specialist in the trailer industry and had him look at my setup (https://www.canamrv.ca/blog/category/hitch-hints/) and as a result made some changes. First they found that the tongue weight was actually closer to 540 lbs and the 600 lb bars were not doing the job. Those got changed to 1000 lb bars, and we put two sway bar controls on the WDH. Plus they added a shorter custom shaft which brought the trailer in closer to the vehicle. That completely fixed the problem of getting pushed around on the road. Andy also suggested a lower profile tire if we needed to tighten things up a little more. (we stayed with the 18" tire as things were now fine).
Then we took off for a 5,000 km round trip from Ontario to Nfld and back over 3 weeks. I would not recommend the cruise control. The five speed has a hard time in 5th gear at 2100 rpm keeping the speed up to 100 Km/hr. A small hill while in cruise was downshifting me as low as 3rd and hitting 4 to 5K rpm. The sudden rev is alarming, so we turned off the cruise. So if you want to travel at 100 Km/hr or 60 Mile/hr you will have to stay in 4th gear and keep the revs up to 3000 rpm. It moves along nicely then, and you will still get 12 to 13 mpg. For the larger hills just keep it at the 3000 rpm and let the downshifting happen. It pulls nicely up any incline, just don't push it for speed. Keep it at 3000 rpm.
I hope that helps. Since then we have upgraded to the 2017 JGC Overland, V6 with 8 speed and pulling the Coachmen Apex 215RBK like it is nothing and having lots of fun. Stay safe out there.
44,071 PostsLatest Activity: Aug 30, 2026
