Max_s_Mom's avatar
Max_s_Mom
Jeep Gladiator Overland Tow vehicle
Hello, I am new to the forum, but not RVing. New to towing, always had a motorhome. I have a Jeep Gladiator Overland. 8-sp Auto trans, with tow package, class IV hitch. Manual states 6,000# tow ability, 600# hitch weight, 1083# max payload, 11,100 GCWR. Specs state a frontal area of 40ft. I have a Redarc Tow-pro Elite Brake Controller installed. I want to tow a FR Surveyor Legend 202RBLE, dual axles, UVW 4931# (brochure), hitch weight: 497#, CCC: 2566# (I doubt I would ever load this much) ext. height 11'2", ext. width: 96", ext. length 24'4".
I plan on using an Andersen WDH with Sway control. I don't load my truck down, normally solo travel or only with one other person. Please comment on this rig so I can better figure out if this is the correct tow vehicle for this trailer or visa/versa. I haven't ordered the trailer but do own the 2021 JT. Thanks for your comments!
  • You may want to check Motor Trend's 2021 Truck of the Year comments regarding the Gladiator and towing. They tested Ecodiesel and Mojave trim versions towing a 5,200# Airstream with no WDH. Their comments were the Gladiator was scary and borderline dangerous.
    If I was going to proceed, I wouldn't use the Andersen but would jump to a heavier hitch with more stout anti-sway capabilities. The actual weight of that trailer with options, propane tanks and battery will far exceed 5,000#.
    Good luck and welcome to the forum.
  • If you want to stick with all the specced tow ratings, you would already be way over on frontal area. 40 square feet limits you to just a five foot high frontal dimension if the trailer is eight feet wide. I think you might bump up against your GCWR, hitch weight and payload limits as well. The Gladiator appears big and beefy, but the nuts and bolts beneath that beefy exterior, not so much.
