Dcarner wrote:
What is your preferred method of stabilizing your TT with the stabilizers. I'm looking to make my unit as rock steady as possible.
I bought 2 5,000 lb scissor jacks from Harbor Freight. I permanently bolted them to the trailer frame 1 on each side near the wheels. When I set up I deploy the tongue jack then go to each side and put the scissor stabilizers down. then I deploy the electric stabilizers front and back. The last thing I do is put Bal X chalks between the tires. I have a triple slide and get very little movement doing it as described. Prior to this the movement was a lot and very annoying.
