jmckelvy
Feb 04, 2014Explorer
Fisher Bill wrote:
Hey Guys,
Thanks for the responses, so when I turned on the thermostat with the propane off I got heat from the from the two blower vents under the dinette are, there are also two vents coming out from under the stove area where the propane tanks are located and nothing came from those vents so I just assumed it has an electric heater.
I'm sitting here at my desk so I'll try the ideas posted and see what happens when I get home.
Look forward to learning from this site, thanks again for the posts.
Bill
You need to double check your propane valves. The two blower vents under the dinette are from the propane fired furnace, which by the way uses 12 volts. Your propane must have actually been turned on.
The other two vents, at least on my 990, are not powered and are just to allow heat access to the basement area to keep the tanks from freezing.
44,068 PostsLatest Activity: Jun 01, 2026
