Taco
Jul 08, 2013Explorer
If it is shifting back and forth while staying on the same hill with tow haul and cruise on there is something wrong.
I will go into 6th while towing but it is rare. It is completely normal to run 5th gear at 65 mph (2250 rpm) and shift once to 4th (3050 rpm) to go up a moderate hill (3%). It will hold 4th till it levels off or goes down hill and will go to 5th. It should not go back and forth on the same hill. If you get the right feel you can get it to hold a higher gear on a hill if you want. However if you push the pedal yourself you can also get it to shift back and forth by losing speed in 5th pushing harder till it shifts to 4th then backing off to try and get it into 5th again.
For what it is worth the gm 6.0 with the 6 speed will put more power to the wheels at every ground speed than the old 8.1 and the ford v10. It will just do it at a higher rpm.
