ryanw821
Oct 05, 2015Explorer
Need-A-Vacation wrote:
After I have pumped antifreeze through all the lines, I will release some of the line pressure from a faucet, but not all of it. I then go out and push the city water check valve in CAREFULLY to allow antifreeze to come out.... USE CAUTION if you choose to do this as the water line is under pressure still from the water pump!!!!! Wear eye protection at the minimum, if not more....
My city inlet has a screen on it, I am not sure how I would push in its check valve, I am going to have to figure this one out, I might just make or order an air hose fitting for it so I can just blow it out with my compressor.
44,057 PostsLatest Activity: Mar 12, 2026
