romore
Aug 25, 2013Explorer II
Address it now before it spreads. The best (and most expensive way) is to peel the roof back and replace the damaged framework. You might get away with replacing the vent, it may have a cracked frame if somebody got overzealous with a screw gun. If there is enough holding wood left, use longer screws and re seal the replacement with putty tape and lots of silicone. The new one should have a metal frame, the cheapies are plastic. If the screws don't bite it is going to be major.
44,066 PostsLatest Activity: Mar 14, 2015
