bobbyg123
Aug 25, 2013Explorer
The area is pretty small, the roof is in tact, and I've got a 12"x6" piece of plywood ready to install. My hope is that it'll be dry enough to adhere to both the underlayment (the remaining layers of plywood that are in decent condition, and the EPDM roof. If Gorilla glue, or whatever I select, does the job, I don't think it'll be a big problem. The rot hasn't extended to the gutter, and there's no sign of delamination yet.
If nothing else, I found the problem early enough where the damage didn't eat all the way through to the cabin. I've got it fairly dry now, and I can assure you that this cover will be installed correctly and sealed water tight.
44,066 PostsLatest Activity: Mar 14, 2015
