westend
Aug 25, 2013Explorer
If you can visit a local roofing distributor, they can set you up with the proper EPDM adhesives and sealants.
One suggestion on the repair: If possible. wrap the interior frame of the skylight opening from over the top of the frame and down flush with the ceiling. I used conventional. self adhesive window wrap to seal the window and vent openings like this. It will direct any leaking on the inside of the frame down to the interior instead of into the roof cavity. It's easy and it's cheap.
44,066 PostsLatest Activity: Mar 14, 2015
