dodge_guy
May 02, 2016Explorer II
If you still have the stock gearing (probably 3.73) with the larger tires, the V-10 will definitely struggle. you will want a minimum of 4.56 with larger tires. I went from 3.73 to 4.30`s with stock size tires, and I definitely could see me running 4.56`s with stock tires. towing anything over 8k lbs will require 4.30`s with stock size tires.
You definitely want 4.56`s! and then get a tune from 5 star!
44,056 PostsLatest Activity: Nov 19, 2013
