Buzzcut1
Sep 08, 2014Nomad II
dakonthemountain wrote:
Buzzcut, I'm confused.. You had to drill holes in your roof??! I installed one of these on my Weekender and already purchased another one for the 1055.. but I didn't and don't have to do any drilling.. I remove the 2nd screw from the front and from the back of the existing Fantastic Fan flange on both sides, fill the holes with Dicor and use the included pan head screws in the holes with the mounting brackets. then the cover instals with removable clip pins like I see in your photo...
Dak
That was the plan, however the fan on my roof has no screws to remove, just a bead of dicor all the way around. I drilled into the flange itself where the screws should have been and sealed everything with Dicor.
