krobbe wrote:
The Kumho 857 is a LT tire for commercial light truck, transporter, van and trailers. Only available in 14", it has an 8ply strength (actually twin steel belted with 2ply poly cords) D load range with Q(99mph)speed rating. In 205/R14 it has a max load of 2271 @ 65psi.
I just installed these on my trailer. Wish me luck.
Ok, I'll wish you luck :) "good luck" ;).
If your experience is like mine, you are going to like them very well indeed. I have a set on my trailer that are coming up on 4 years now, over 25K miles. Much of my pulling is in very hot weather. The Kumho's have worked just fine. They seem to run cool enough, easily lay my hand on them right after stopping from hiway speed, and my non contact IR thermometer shows them to be typically only about 15 to 20 degrees above outside ambient temp.
The have now worn just over 2/32" off of original tread depth, so it's pretty obvious to me they will age out before they wear out.
The only reason I did not mention them in my post above is because as far as I know, as of right now, the only size available in NA is the 205-14. This tire is 27" in diameter, and some trailers may not have clearance for them. On mine, I am using 185-14 which are slightly smaller in diameter (25.7" as I recall ). That was critical in my particular application.
The Hankook I referenced is currently available in 185-14.
Barney made a good point that a P tire might well be a good choice for the OP's trailer. Hopefully the OP will come back with the make/model/weight of his trailer.
