- donn0128Explorer IIThats crazy! Throwing parts at a problem without doing any troubleshooting. Check batteries first. Check air filter remove and carefully clean grid heater.
BTW your not using one of those cruddy oiled filters are you? - BeentherefixedtExplorerI agree with those who say you have a problem. My 2016 Ram TDSL started at well below -20 deg on the Alaska Highway without being plugged in overnight.
(all the plugs at the motel were taken) - PiciniscoExplorer
memtb wrote:
How cold is cold? As others have mentioned.....is your intake grid heater working at all or properly? We can and have “many” times started ours at -20 F. Until you get it checked-out....you may try “cycling” the grid-heater twice and then attempt a start.rhagfo wrote:
Describe cold, 40, 30, 0 or colder.
You may be right. Im in southern AZ so cold is 40s and 50s.
Will replace the heater grid first. - Mark_HeislerExplorer II2 things
How cold is it?
What weight of oil are you running?
Any thing after -5F you should be plug your truck in. if not the truck will knock like crazy running 15w40 oil that pretty thick for winter use if not plugging in - memtbExplorerHow cold is cold? As others have mentioned.....is your intake grid heater working at all or properly? We can and have “many” times started ours at -20 F. Until you get it checked-out....you may try “cycling” the grid-heater twice and then attempt a start.
As mentioned you may have a bad heater. One of the things that can/will shorten the grid-heater life expectancy, is to bring the engine rpms up (in excess of 1100 or 1200) until you see the amp/volt meter quit cycling. The drawing of excess “cold” air across the hot grid-heater, is pretty hard on it. The Dodge/Cummins manual used to warn about this! - ScottGNomadSomething is very wrong. The Cummins will start fine even without grids at temps to -20F.
It may be getting close to needing a high pressure pump and/or injectors or something else. How old are your batteries? If the ECM doesn't see a minimum engine speed during cranking it will not fire the injectors.
Rather than do anything else, I would get it looked at. - rhagfoExplorer III
Picinisco wrote:
My dodge dually Cummins engine is very hard to start when cold. At home or camping with hookups I can plug in the block heater but what can be done when boondocking.
Describe cold, 40, 30, 0 or colder. Many times I don’t even wait for the wait to start light to go out, just crank. With full heater grid cycle starts right up!
Check out your heater grid, also how many miles! - PiciniscoExplorer
Ductape wrote:
Is your intake heater working properly? That engine should start fine in the cold. I had the same truck.
It seems to be but is it something that can deteriorate and still show that it is working? - DuctapeExplorerIs your intake heater working properly? That engine should start fine in the cold. I had the same truck.
- ShinerBockExplorerIs your grid heater working properly?
44,026 PostsLatest Activity: Feb 22, 2025
