tony_lee
Sep 09, 2014Explorer
Unless your furnace directs hot air down into the basement such that all tanks and pipework are kept above freezing at all times (a big ask unless all holes are blocked and all hatch doors seal effectively and required insulation is installed correctly and is in all the right places which is doubtful) you might be better to start out completely winterised and use bottled water for everything including toilet flushing and add enough RV antifreeze to dose grey and black water as the tanks fill to keep them from freezing solid. Still need to run the furnace while travelling to keep the temperatures at least above freezing inside, but at least you won't have to worry about the water and waste system
