brulaz wrote:
Trailmanor sent me some of that RV Gutter stuff when I complained about a leaky window (the "emergency" window had a joint between two Al pieces on top, not where it was sealed to the trailer but in the pane that tilted out from the frame).
The gutter was easy to apply, worked well and is still there after several years. You might want to ensure it's installed with a slight tilt so it drains to the side.
On the other hand, if it were me, I would get the topper.
I am considering the topper, however there is only 3.5" between the slideout and the bottom of the gutter when it's fully retracted. Is that enough clearance for a topper?
