hohenwald48 wrote:
I've not seen anything where the OP says there is no label so I fail to see the relevance of your post.  And tires and axles rated for less than GVWR is not that rare.  But what do I know, you're the lawyer here.  :)
Your ignorance is not my problem, nor is your inability to read the college level English in which the regulations are written. He said the tires and axle were rated for less than the dry weight of his 2010 Wolf Pup. They have a 3500 lb GAWR (3822 GVWR), and a dry weight of under 3000 lbs, which would put such an axle/tire combo in violation of FMVSS regulations, regardless of any labels. It's the GVWR you keep bringing up which is irrelevant.
And it's was the GP. The OP has a Keystone.
