pjw73nh
Apr 19, 2020Explorer
Keystone Bullet Premiere 19 FBPR Roof repair help
Started my annual maintenance on my 2011 19' FBPR Keystone Bullet Premiere TT. While up on the roof sealing some questionable areas with self-leveling caulk, I found an 18" or so spot on the drivers side, above the slide where the underlayment material that wraps over the edge has "lifted". As it rounds over the edge of the side to the top, it has pulled the roofing material away from the underlayment. If I press down (as seen in the video) there is solid material underneath the lifted area.
Pic & Video here
What is the best way to repair this? I was thinking perhaps a row of 4-6 short, stainless screws with either rubber washers, or stainless fender washers (or maybe both) then either topped with self leveling caulk, or perhaps a 6" x 24" strip of roof repair material over the screws.
Any thoughts, much appreciated. Thanks.
Pic & Video here
