Lantley
Feb 09, 2018Nomad
RVhiker wrote:kbooky wrote:
... The latches should be such that they need to be unlatched. Driving down the road caused them to open...
The OP says the doors were properly closed using whatever latching mechanism the manufacturer installed and the doors opened due to driving down the road. Assuming the design was to keep the doors closed when driving down the road, then of course the design is flawed.
Manufacturers often use **** inadequate to the job when building trailers. Why cry operator error when it's the manufacturer's design and install that failed?
TO some extent the OP has a valid point. It's not that he forgot to close them. Its that the latch is not designed to keep them closed during travel.
Sort of like your car door opening if you hit a big enough bump.
It should not happen or even be possible.
