DutchmenSport
Jun 05, 2017Explorer
Yes. Those quick connects on the Keystone Campers are set up to use a suburban cook stove. If you have a different stove, or a BBQ, it might not work well as the main pressure regulator at the trailer tanks might not match the required pressure for a different BBQ grill.
My Keystone Outback has the outside stove with the quick disconnect. There is no pressure regulator on the actual stove as the connection is after the main regulator.
If you want a separate line for an external BBQ with its own regulator, then you are best to a T at the propane tank. One side of the T goes into the regulator for the camper, the other side does not. You can use it to attach anything you want with it's own regulator that way.
44,070 PostsLatest Activity: Sep 18, 2026
