dblworkingmom's avatar
Apr 03, 2017
Keystone Furnace and outdoor stove WONT LIGHT HELP!!!!!!!
OK in the fall we purchased our 2010 Keystone Laredo 291TG. The first time out the furnace worked, though we did not check the outdoor stove and we only started it briefly and waited for it to blow warm air then shut it off (just checking if it worked). A few outings later we needed to use the furnace due to the temp dropping over night, BUT no heat :( so furnace was not working just blowing cold air for about 30 seconds. BIG bummer. I figured ok this is our last trip we must be almost out of propane the indoor stove would light but I has assumed we did not have enough propane to get back to the furnace, refilled the tanks this spring (they were almost full to begin with) and still NO furnace and this weekend found that the outdoor kitchen stove would not light either. We can smell propane at the outdoor kitchen but can not get it to light. Does anyone know what the problem could be? Is there a valve I might be missing? Sure hoping not to have to take our "new" baby into the shop already :( any Help would be greatly appreciated!
  • DiskDoctr I'm pumped!!! Thank you so much I hope this works will be trying it tonight!!! Let you know how it goes, don't want to have to pull the whole darn furnace out since for some stupid reason they have the access door to the back. Of the furnace but not to the front. @Mandalay we had it hooked up, not boondocking at least not with the furnace yet.
  • You must have good solid 12 volts to operate the furnace. Fan speed must be top notch.
    If need be a mobile tech could help.
    Are you plugged in or boondocking?
  • Probably air in the lines.
    Here's how I do it. Use a BBQ lighter.
    Reset the system. Turn off the fridge. Turn off the propane tanks, hold the lit lighter over the stove burner and turn on the burner. Let it run until no more propane or air comes out of the line. This reduces the pressure on the "leak protection valve" in the propane tanks.
    Disconnect the propane lines from each tank. Wait about a minute or two and reconnect them.
    Make sure all propane appliances are OFF. Stove, fridge, furnace, hot water heater.
    SLOWLY open one valve on a tank. If you hear a SNAP, then it was too fast and the leak protection engaged and shut off the flow. The valve should be opened completely. Repeat if you have a second tank.
    Go inside and use lit BBQ lighter over a burner and turn that burner on high. Don't let the air blow out the flame. When the air is purged, the propane burner will light. Leave it run and turn on all the stove burners and let them run about 20-30 seconds. Turn off burners.
    NOW you can turn on fridge, make sure it lights. (you can hear a low roar near the outside fridge vent when running on gas)
    NOW you can turn on the furnace. It may blow up to...maybe a minute(?) as it purges air from the line and gets happy with the safety sail switch and such. Then you'll hear it light.
    I believe it is quite likely that you had air in the lines, or propane not flowing (leak detector valve closed?). The fridge and furnace have safety devices that can be troublesome if they repeatedly fail to light (as air is purged from the lines).
    Lighting the stove burners first, each time the tanks have been off or disconnected, seems to be 100% reliable way to avoid such troubles.
    You shouldn't need to reset the system each time, just purge the air after the tanks have been off or changed. But since you are having trouble, it is best to do the full procedure to test your furnace.
    Hope this helps! Let us know how you make out ;)
    (Hope this message gets posted. Stupid Captcha all over this site :G )
