star6443's avatar
star6443
Keystone Springdale TT
We are looking to purchase a 2008 Keystone Springdale 296BHHssr. Anyone have any recommendations on what I should be extra careful to check on this used camper?
Also has anyone had any luck removing exterior decals as they are all peeling off, should that be a deal killer?
  • My 2006 is losing decals. 3M eraser wheel, vinyl adhesive solvent along with some elbow grease will get it done. I have had no real issues but the biggest thing to watch for is water leaks and soft flooring. Otherwise test all systems and go have some fun.
  • Decals, no. Not a deal breaker. 2008 model? check the frame. Check the trim inside. Check the wiring that goes to the brakes to make sure they are not fraid by rubbing against the axle.check the roof to make sure the rubber membrane is not getting to thim or flaking.check the weld on the a-frame tongue.
