beemerphile1
Jan 30, 2014Explorer
amandasgramma wrote:beemerphile1 wrote:Well, it must have been an amateur that installed it.......using brackets should work fine...it did on our rig.
You need a pro to determine the material, the correct adhesive, and do the repair. This is not a job for an amateur. A company that does custom kitchens can either do the repair or recommend a local shop that can.
Be prepared to be told that it cannot be repaired and that a new counter and sink are needed.
If it is solid surface DuPont Corian material you cannot 'add' brackets.
If memory serves the Corian brand has a lifetime warranty. I don't think it would cover this due to it being a failure of the assembly, not the material.
