Jayco23FB
May 09, 2014Explorer
K&N Air Filter?
I am thinking of getting a K&N cold air kit for my 2007 Chev 2500HD 6.0L gas. I would like to here from those that have used them or any issues with these filters. Thanks
marcsbigfoot20b27 wrote:
snip...
I have a 99 Tahoe which is probably the same as whatever your GMT 400 is.....as far as intake.
Not sure what the "max airflow" is, but I monitor the intake air temps live and found that after any heat soak from sitting at a stop, when moving for more than a few miles, the intake air temp OEM is within 1-3 degrees of ambient. For that reason I never modded the air intake.....but I did take a good look at it. If you look under the passenger headlight there is a scoop that directs air under the battery to the fender/airbox via a duct.
I ended up with OEM airbox with k&n.
