Farmboy666
Jul 09, 2018Explorer
Lynnmor wrote:
If it has no gravity fill, then you open a valve to direct the city water to the tank. It is also possible that a winterizing hose is used to draw in fresh water and direct it to the tank.
Either way you have a valve somewhere close to the tank inlet you need to turn to open for filling and using pump for pressure or close to use city water pressure.
44,067 PostsLatest Activity: Jun 05, 2026
