JimNH's avatar
JimNH
kz 16RBT Screen Room for Awning?
my wife wants to add a screen porch/room area to our KZ 16RBT. I believe the awning length is 10'. Does anyone here have a recommendation for a (hopefully not too expensive) brand or source for such a thing? I imagine it might require not using the stock awning for the trailer, since I don't see any way to fasten the sides to the existing roll up awning. Thank you.
  • thanks - I don't think she'd be OK with that, though. Something commercial and at least a little bit good looking I think.
    I could use this screen as a starting point to make a semi-permanent one myself though - maybe build a set of lightweight panels that clip together or some such.
    I'll at least take accurate measurments the next time I am there.
  • Harbor Freight has a screen that you can install in a garage door opening its 16' long and 7' high. for about $25.00. if you need something quick this works, I got two of them and used clothes pins to hold it to the awning.
    Double Garage Screen Door
    SKU 68310
