wnjj
Jul 24, 2021Explorer II
Surgtech94 wrote:
Thank you. I will level it. The dealer told us to turn the battery off when at home I. The driveway and turn it on when we’re traveling and turned on at the campsite? I made sure the cord to the camper was plugged in and the ring tightened. It’s just weird when it was plugged in Thursday and it got cold and was cold yesterday and then this morning it was warm.
The suggestion to turn off the battery was assuming two things:
1. You aren't "using" it at home (i.e. fridge is off)
2. You aren't plugged in.
Turn the battery on unless your trailer is in storage. While you can use the 12V power from the 120V AC->12V DC converter when the 120V power cord is plugged in, it's possible the converter may need a battery in the circuit to smooth out the 12V. If the converter is making a noisy 12V supply with the battery off the fridge control board may be glitching out and shutting off.
