Gdetrailer
Jul 26, 2021Explorer III
Surgtech94 wrote:
Wasn’t cold this morning. We’re up camping and refrigerator sounds like it’s running, freezer compartment is cold but refrigerator section is warm, freezer is only cold like the fridge should be
Explain "sounds like it's running".
Absorbsion fridges have no compressor to make noise when running, they are basically silent under normal operation.
Yours may have a set of 12V fans behind the fridge to "help" with fridge operation but those do not really cause the cooling to happen and are not part of the fridge but an add on by manufacturer..
If you are hearing bubbling or gurgling you are out of level or fridge has internal blockage or in extreme cases cracked/ruptured cooling unit (but you will smell the strong odor of Ammonia while operating if a leak has occurred).
