star6443's avatar
star6443
Lack of Power to slide
We were camping without power this weekend, so our camper battery was nearly dead. When pulling in the slide it came in slowly and stopped without the normal grinding noise that says it is DONE! So I double checked to make sure it was in and it was. When arriving home and plugging in to electric, there is still no sign of power to the slide and it will not extend. There are no visible fuse issues, the automatic awning switch above the slide is working.
Any hints or suggestions would be appreciated. Really didn't think I had time for a hour trip to the dealer this week. As we are heading out again on Friday. Thanks in advance.
  • Generally speaking, a well charged battery is essential for proper slide operation regardless of whether or not you are plugged into a power pedestal. You probably need a new, fully charged battery.
  • More than likely, your battery will need to charge up first. Mine specifically has a label by the switch that says a battery must be connected for the slides to work. Your on-board power converter/charger does not have enough "umph" by itself to move the slides. You'll need to wait till it's charged up.
  • Slide out is wired directly from battery.......battery does not have enough charge after you ran it way down.
    Awning works off DC being supplied thru dist panel (converter when in shore power)
    Charge battery and trace wiring back from slide to battery (or from battery to slide motor) and find in-line fuse (or small box with 2 studs....circuit breaker)
    FUse could be blown (or CB tripped...small reset button)
