wintersun
Mar 23, 2014Explorer II
travelnutz wrote:
Redsky,
Going from 245 tires to 285 tires is just under 8% difference not 4% if both sizes were 75/16's "E" range and inflated to 80 psi. Here's a quick calculator for tire size differences:
http://tire-size-conversion.com/tire-size-calculator/
There are many others that give more info on tires and tire differences and the effects.
"IF" is the operative word. I replaced 245/75R17 tires with a 31.5" diameter with no load, with 285/70R17 tires that with no load have a tire height of 32.76". The 245/75R17 tires have a theoretical 641 revs/mile and the 285/70R17 tires have a theoretical 617 revs/mile.
That works out to a difference of approximately 0.0374414976599064 which I rounded to 4%.
But it is theoretical as I do not know the revs per mile with a 3,000 lb. load on these 3750@80 PSI tires. Obviously there is sidewall flexing that reduces the radius of the tire and with it the circumference so there are actually more revs per mile traveled (which is what the odomoeter and speedometer are using for their inputs).
In my own experience with the two sets of tires my mileage and speed readings were accurate with the stock 245/75R17 tires and no heavy camper load in the bed and were also accurate with the new 285/70R17 tires. Empirical results are what count in the real world. Beliefs are what get us into so much trouble and cause so much grief in the world.
44,056 PostsLatest Activity: May 04, 2014
