Sglloyd's avatar
Sglloyd
Lance 1121 compatibility
Hi all,
Me and my lady are looking to add a ruck camper to our lives. We have been looking around and found one we both really like. It’s a 2000 lance 1121. We have a quad cab Dodge Ram 2500. I’m going to add airbags regardless of what camper we add. And I’m wondering if this camper will safely load into the standard 6’4” bed. I’ve heard rumors about leaving the tailgate down and strapping it to the bed. Can you folks help point me in the right direction?
Thanks.
Sam
  • Doubt if you will find much support on here for that setup. Some things not working in your favor would be the center of gravity(COG) of the TC, which is probably going to be a ways past your rear axle; the weight of the TC-the brochure says a little over 2900lbs-but that is before options. I had a lance 1130 that the brochure said weighed the same as the one you are looking at but the actual weight was right around 4000lbs be fore I put water, clothes, food etc in it. The rear hangover including the bumper was over 3' and I had an 8' bed. Consider that with your shortbed. The single wheels on the rear of your truck are also something to consider. There is probably no way that I would even consider doing this. If you really like the TC possibly consider sitting it on a trailer and pulling it with your truck. But this probably defeats the purpose of having a TC. Gary
  • Sometimes you can get by with an 8 or 9 foot camper in a shortbed, but that campers an 11.5 footer with a slide out. Unfortunately you'll need an 8 foot bed with that one.
