Geterdone's avatar
Geterdone
Lance 1172 plug wiring access
I want to install a new Lance plug onto my 2013 1172 TC. Is there any info on:
1. how to access the wiring source in my TC
2. how to run power from the battery etc to the receptacle, or where to splice receptacle to existing wires. (Ram 3500 dually, 2014)
thanks,
Geterdone
  • Morning Everyone.
    I have replaced a couple of "Camper Side" pigtails for Lance 1172s.
    Inside the R/V, you need to remove the carpeted step that you stand on to climb into the cab/over. You do that by finding the screws hiding in the carpet. Once you find all the screws (5 I think) - voilà the plywood step can be removed.
    To the left of that step, is a smaller carpeted piece of plywood. One time I had to remove it - one time I did not. Same procedure look for the screw heads in the carpet.
    Lance makes it very miserable to change out that Camper Side pigtail. To the left of that black Atwood Board is a couple of cut/outs in that piece of wood that supports the Atwood board, where wires are coming thru. Once you wade thru the rat nest of wired, you should be able to identify the black & white 8 ga charge wires that come from the T/C pig tale.
    I found by removing the screws that hold that plywood with the atwood board and the mess of ground wires and the 2 grounding bars, you could slightly slide or lift that plywood to the right and access the lance pigtail
    Good luck
    Mike Tassinari
    P/S - I need a bit more specifics before I cam answer your second question.
    p/m me and we can exchange phone numbers and chat. Mikeee
  • Run an 8 gauge wire from the + battery post battery through a 40 amp relay to the Lance Bed Plug for charging , don't splice into the undersized wires of the trucks wiring harness.
