burningman
Jan 17, 2017Explorer II
You are correct, they did do an in-tank pump retrofit for that reason - but it was just as bad!
There are now very good aftermarket pumps, usually frame mounted, that completely resolve the old
Dodge lift-pump issue. Those are the hot setup now. Plus fuel filter changes are an easy no-mess deal now; just slide a bucket under and unscrew it. The original setup is on the side of the motor and filter changes were a mess.
One benefit to running a truck that's been around a while (and popular) is all the design issues have been discovered and sorted out.
44,056 PostsLatest Activity: May 04, 2014
