recycler
Jul 29, 2013Explorer
you should be ok if you drive it reasonable..if you don't have a rear sway bar i would look into a helwig unit to deal with the high center of gravity.. ford used the same model rear axle as your truck under mid 90's super duties and they had 11,000lbs gawr..biggest thing is if your comfortable with it..i was going to run my fraklin which is nearly that heavy on my d250..
44,056 PostsLatest Activity: May 04, 2014
