Sam_Spade
Dec 26, 2016Explorer
Shadow Catcher wrote:
The goal is to keep the battery above 50 percent state of charge.
When you go below this permanent damage to the battery occurs.
Your goal should be to keep it above 90 percent as much as possible.
And that second statement depends in part on what KIND of battery you have and how LONG it stays at that low level of charge.
One that is designed for "deep discharge" won't be harmed significantly by an occasional dip below 50 percent.......IF it is recharged right away.
