Fuller_Johnson
Dec 26, 2016Explorer II
The First thing to find out is, Is the truck charging the camper battery. Sounds like it might not be. On some GM trucks you have to put in a fuse before power will get to the camper to charge the battery while you are getting to the destination. You will need a good voltmeter to check this. After running the truck for a while camper battery should read around 14 volts while the truck is running.
