kohldad wrote:
As you can see a simple piece of sheet metal with one bend and cut to fit around the pipe. The foam was to seal the air gaps which create a draft in the corner under the furnace overhang.
Thanks for this, and interesting. It definitely seems to show a cover over the fresh water tank! And that cover seems to make it appear that the pipe somehow comes off the back end of the fresh water tank (it doesn't, actually). Maybe I did have a cover on that and just don't remember.
Glad to see the missing piece is just a piece of sheet metal. That'll be easy enough to make up for sure, and I've got a can of expanding foam left over from another project.
