c_traveler2's avatar
c_traveler2
Nomad II
Jan 06, 2020
Lance 815 Stove Replacement
It's been awhile since I've posted anything on RV.net. I made a video of installing a replacement 2 burner stove in my 2002 Lance 815, the old Atwood was worn out so it was time for a new one.
Stove Replacement
  • kohldad wrote:
    That is the same stove that came factory in my 04 Lance 815. Looked like a nice easy swap. Just be careful with a large pot on the right burner as the heat may come off the edge and melt the knobs. Not from experience, but from the previous owner. I haven't had a problem but only use a 4qt pot on the right burner.
    I did take note of that burner and thanks for the information.while searching for a new stove I discovered that there's simply not a lot of choices.
  • That is the same stove that came factory in my 04 Lance 815. Looked like a nice easy swap. Just be careful with a large pot on the right burner as the heat may come off the edge and melt the knobs. Not from experience, but from the previous owner. I haven't had a problem but only use a 4qt pot on the right burner.
