Grodyman
Oct 03, 2013Explorer
smooth1 wrote:
They are in the upper dinette storage cabinet on the drivers side. There is a box on the upper right side of that cabinet that has the wires - one blue (pos+) and one white (neg-). The same blue wire is bundle up in the battery compartment and the white ground wire is allready connected to the main grounding block. This was on a 2008 830. Just did a 100w panel and sunsaver duo controller, so let me know if you have any questions.
Thank you very much Smooth1. Mine is 2011, should be same. We'll see. Gman
