wintersun
Oct 04, 2013Explorer II
Lance uses thin 12ga wiring so IF you can find a 34 volt panel instead of a 17 volt one there will be less current loss. Alternative is to wire two 17v panels in series.
The most difficult part of my installation was mounting the panels on the Lance TPO roof which consists of a very thin plastic membrane over 1/4" luan. Not the kind of roof where you can screw down brackets or use VHB tape.
I made a frame that I attached to the side corner sections of the camper. The easiest approach is to bolt the panels to the factory roof rack (which is attached to the side corners of the camper) if your camper has one.
