dlduke01's avatar
dlduke01
Lance 920?
I have a 2007 ford f350 srw truck and currently have a 2007 lance 815. I have an opportunity to get a 2006 lance 920. The question is can I haul it easily with out modifications to my truck? I think the weight of the 920 is about 2775 pounds. Thanks for all your input.
  • I had a Lance 920 on my 2004 Dodge 3500 and it carried the camper just fine with no mods.
    Big Rig
  • That should be a good combo.
    The lift will hurt a bit but you should be fine.
  • I have a 920 on a Dodge Ram 2500 but with several suspension modifications. You should not any problem with the weight but you might want a beefier anti-sway bar. You can expect approx 3,600 lbs wet. Good luck!
  • Can anybody give some insight? I gotta move kinda fast on the deal.
