paul_arc's avatar
paul_arc
Lance camper draining battery
I picked up a 2016 lance 865. It is killing the truck batteries when plugged into the truck. If it sits for a couple days without starting the truck then it is really slow to start.
On the plug I installed on the truck, I did NOT wire the 8 gauge 12v wire to the battery. I have the 8 gauge ground connected to the truck chassis. Then the rest of the wires in the plug are just turn signals, brake lights, running lights, and reverse lights. I tapped those into the 7 way at the rear of my truck.
Without the camper plugged in then the truck can go weeks or months without being started and it starts fine. With the camper plugged in, then it can only make it a couple days and it is slow to start the truck.
Any ideas? Also This still happens when the 120v is plugged into the camper to charge it.
