4x4crazy wrote:
Camper weight is 1900lb dry. Truck doesnt have the camper prep package but it does have the fifth wheel prep package with the 7 pin connector in the bed. Are the airbags better than timbrens?
I have a much heavier camper on a 17' long bed SC.
Both the timbrens and air bags will work. Airbags are adjustable, timbrens not so much. Airbags will allow you to level your rig with the camper on it but since the rear is effectively riding on two balloons it will be bouncier and have more sway then the timbrens.
The timbrens won't level the rear end but the rubber bump stops are progressive and can reduce the amount of rear end squat.
Unless I'm mistaken I thought the 945 is a 9-9.6' camper wanting a long bed to haul it around on. Learn something new everyday.
