GB590
May 19, 2018Explorer
Well, I finally got around to tearing into this. Literally.
For those who are curious, the lower section on this is sheeted with 3.6mm thick paneling according to the stamp on the back of the sheeting. Mine is nice and dry behind my delaminated panel which is awesome. Smells like new wood in there surprisingly! It appears the bottom is sheeted with the same thickness, but doesn't have the same texture.
My plan is to use textured FRP paneling from the local big box store and structural adhesive and a few staples to hold it on. It's thinner at only 0.090" thick per sheet as opposed to the 0.140" of the original sheeting, but I'm hoping the 0.050" difference isn't a big deal anywhere. I don't really see why it would matter honestly. I plan to resheet the side that's removed, the "top" of this area, and the whole bottom of the camper with the sheeting. I should be able to do it with 3 or 4 sheets at about $35 a sheet, so not too bad!
Photo of the reason I tore into it (previous owner had been trying to use some kind of tape to seal the edges which are left unsealed from Lance):
Photo of the panel (and fiberglass insulation) removed:
Hope that helps anyone else who might be looking like I was and curious. I might update this as I go along if anyone is interested in the repairs.
44,056 PostsLatest Activity: Jan 22, 2026
