mooring_product's avatar
Jul 13, 2013
Lance solar wire locater.
rewiring the existing solar on my 06 Lance 881. The old owner ran the wire down the side of the unit in a plastic wire cover thing. I want to use the pre-wire set up Lance installed.
I found the roof connector set up with the plug but am having a hard time locating the wires below.
Here are what I found. A blue and white wire is what i have determined are my pos/neg but i can only find the blue wire under the sink by the battery. Not sure what happen to the white?
Any info would help.
Here are the two wires from the roof.
Solar wires by MooringProduct, on Flickr
This is all I can find under the bathroom sink by the battery
  • I found my diagram from lance if you want to private message your email I'll send it to you, should be similar.
  • Its been a bit since I did my 992 but I think you will have the same answer as mine. From the factor the neg gets tied into the camper harness prior to the bathroom and you have to run a separate lead to the battery neg
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25275162/gotomsg/25310318.cfm#25310318
  • My experience and observations:
    Specific questions sbout wiring in specific Lance Brand/Models should not be asked of the general forum... the TC forum... or even me... cause I can't answer even if its something that I've done before..
    I spent a lot of time at the Lance factory... and have helped a lot of people over the years.
    A couple of reasons to check with Lance.
    1) Lance makes minor changes all through the year and documents them to model and serial number. (Thats why you have to tell them the SN of your TC when you phone them (or e-mail)
    2) Lance purchases many componets from vendors through the bid process... Stoves, Fridges, microwaves, wiring harnesses, light bulbs, etc.
    During the production year they may run out of wiring harnesses... if they do they might put out a new bid or extend the onld bid...
    Different vendors may alter the wiring loom slightly as long as it's with in spec...
    Even two campers with successive serial numbers might be different.
    All of the wiring harnesses that I've seen have been set up for the maximum number of optional add-ons, TV's, Generators, etc... your camper might not have the generator... but often the bare end wires are there somewhere... or even be set up and labled as generator ready.
    Another vender may leave out as many wires as possible. They are set up by hand... someone my leave one out accidently.
    The advice to phone the manufacture is always correct!
    A bonus that you get for phoneing the factory... you won't be cutting into the wrong place and shorting out wires, cutting into a water or propane line...
    Lance will e-mail the schedmatic for your specific camper to you .
44,028 PostsLatest Activity: Apr 15, 2025
