av8rds
Jul 13, 2013Explorer
Its been a bit since I did my 992 but I think you will have the same answer as mine. From the factor the neg gets tied into the camper harness prior to the bathroom and you have to run a separate lead to the battery neg
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25275162/gotomsg/25310318.cfm#25310318
mooring product wrote:
rewiring the existing solar on my 06 Lance 881. The old owner ran the wire down the side of the unit in a plastic wire cover thing. I want to use the pre-wire set up Lance installed.
I found the roof connector set up with the plug but am having a hard time locating the wires below.
Here are what I found. A blue and white wire is what i have determined are my pos/neg but i can only find the blue wire under the sink by the battery. Not sure what happen to the white?
Any info would help.
Here are the two wires from the roof.
Solar wires by MooringProduct, on Flickr
This is all I can find under the bathroom sink by the battery
